Old 11-16-2009, 03:54 PM
LarryT LarryT is offline
Default Wheel Bearing Repacking at brake reline
While twiddling my thumbs at work today, I decided to investigate the question of wheel bearing maintenance by referring to the on-line Timken Catalog.
If memory serves me correctly, the tapered roller wheel bearings on my -6A are L15101.
This bearing part no. has a C1 life (1,000,000 cycles) of 10,500 lbs.
The C90 life (90 million cycles with no more than 10% having a small spall on the race) is 2730 lbs.
The static load rating is 12,100 lbs. This is the load that would dent (brinell) the race.
For an RV-7 at gross weight assume 900 Lbs. per wheel = 450 lbs/bearing.
It would take a 27g impact on landing to brinell the race! A lot of other things would be damaged if one dropped an aircraft in that hard.
Some other statistics:
Touching down at 60 mph is about 1300 RPM, not real fast for tapered roller bearings. At 10 mph taxi speed only 215 RPM.
A 5.00 x 5 tire travels ~ 1260 revs/mile about 2x car tire sizes.
Depending on the length of one's taxi it could take almost 2,000 hrs. to reach a total number of revolutions of about 2.5 million or <3% of the C90 life at < 20% of rated load.
The only enemies in this equation are grease rather than oil lubrication (reduces life to 79% of oil bath), contamination and corrosion. Since my -6A is hangared, my conclusion is that cleaning and repacking the wheel bearings is only conservatively necessary at the time I reline the brakes.
Larry
Old 11-16-2009, 04:16 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Never Mind...
Larry
..business should pick up in 2010
Jim Sharkey
Old 11-16-2009, 04:24 PM
frankh's Avatar
frankh frankh is offline
Most bearings fail for one of two reasons.
1) Corrosion
2) Too much grease..Overheats the bearing. If I remember rightly only 60% of the spaces between the rollers should be filled with grease.
Frank
Old 11-16-2009, 07:20 PM
PCHunt PCHunt is offline
1) Corrosion
Frank
I must say that I have never heard of too much grease being a problem. Would love to see some engineering literature, such as a published paper, on that subject.
Not sayin' it ain't so..... just wanting proof. I used to be from MO.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 11-16-2009, 07:51 PM
terrykohler terrykohler is offline
1) Corrosion
Frank
Don't forget excessive end play or preload. Goal in the trucking industry was 0/0. Also, I'm not sure of any automated packers that leave unfilled space.
Old 11-16-2009, 08:07 PM
frankh's Avatar
Just pick up the literature from any bearing supplier..tells you right there. I sat through many a presentation from industrial equipment suppliers..all told me the same thing
Old 11-16-2009, 08:13 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Old wives tale... the grease we use today is far along the road of long life for most all bearings.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-16-2009, 08:26 PM
frankh's Avatar
Really?....you maybe right, but millions of dollars are riding on the answer...but then again the establishment will also tell us running on lead free gas will destroy our engines too.
I know the accepted correct way works very well so I'll stick to that
Old 11-16-2009, 08:33 PM
Well Okay... you do that. My Kubota tractor states, grease every 10 hours... Hmmm? DUNNO...
Reiley
VAF# 671
Friend of the RV-1
Old 11-16-2009, 08:39 PM
Default But...
I also change brake pads every year too, they are too cheap and then I don't worry about it for another year.
Reiley
VAF# 671
Friend of the RV-1
