11-14-2009, 08:08 PM
Cutting Stainless
I'm getting ready to cut some stainless piano hinges and before I destroy my bandsaw blade, I wanted to see if there was another method I hadn't thought of.
Anyone found a trick or method that works for them?
Phil
11-14-2009, 08:12 PM
Fine tooth hacksaw, slow steady pressure, WD-40.
Not good on the bandsaw.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
11-14-2009, 08:14 PM
I have used the cut-off disc on 4 inch angle grinder ......FWIW
11-14-2009, 08:23 PM
I'm thinking I would sacrifice a few cut-off wheels on a Dremel before I destroyed a good bandsaw blade.
11-14-2009, 08:28 PM
Dremel
Second Greg's idea on Dremel. Works good on stainless, make sure your goggles are on the thing throws metal dust at the speed of sound.
11-14-2009, 09:49 PM
Bandsaw
A fine tooth metal cutting band works perfectly fine. I built an entire auto exhaust system for my rod out of 16 gauge stainless pipe and did all the cuts on the band saw. Does not dull the blade, and is not hard to cut.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
11-14-2009, 10:11 PM
Another vote for the Dremel. 3 seconds with a cutoff blade. Quick and easy. Alternative method is using the corner of a grinding wheel. A bit bludgy, but also quick.
greg
Greg Arehart
N 7965A
11-15-2009, 08:05 PM
49clipper
I use my die grinder with a 2" cutoff wheel. Go thru a lot of cutoff wheels, but it works great. And as in drilling, use lard to lubricate and it will cut like butter.
11-15-2009, 08:12 PM
I always use the Dremel cut-off wheels.
Always use safety goggles, not only for the dust but for broken pieces of disc.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
11-15-2009, 08:26 PM
Stay away from the thin cut-off disc that come with a Dremel. Any side load at all and they become a projectile. The fiber cutoff wheels work good. I like the ones with the quick change attachment.
If you don't have a dremel, and you get one, you will ask how you ever got along without one.
After that, chop saw works pretty good.
http://www.dremel.com/en-us/Attachme...Cut-Off+Wheels
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
