Old 11-14-2009, 07:48 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Gear leg faring chord length
I am working on my gear leg fairings for my RV-7A. The farings trailing edge is factory cut and looks like a finished edge. However when the template in the plans is laid over the faring the faring appears to be about 3/8" wider (chord is longer) then the template. The instructions say "don't cut the trailing edge" during the early stages of assembly of the faring but further in the instructions it say "clean up the trailing edge".
I interpret "clean up" as sand straight, not cut off approximately 3/8".
It would be nice to get some clarification. Do you cut the faring to the chord width of the template?
Any help would be appreciated.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 11-14-2009, 08:32 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Just sand the trailing edges straight with a sanding block - when it comes to drag reduction, chord is your friend!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-14-2009, 09:36 PM
Finley Atherton Finley Atherton is online now
IF you are going to purchase pre-made intersection fairings then I suggest that you don't remove anything from the trailing edge till you see how the leg fairings fit in the intersection fairings.
Fin 9A
