Hi Listers
I am concerned about the proximity of the exhaust pipe (4 into 2 crossover, no flexible joint) to the fuel line connector of the carburettor on my RV6 (see photo).
http://i456.photobucket.com/albums/q...c/DSC03055.jpg
The engine is an 0-360 A1A with a Facet model MA-4-5 carb, and the fitting that came with the engine sticks out quite a bit, only leaving about 1/4" of clearance. No room for a heat shield. Is this going to be a problem re heat affecting the fuel/fuel line (fuel vapour etc)? Anyone know of a suitable low profile connector? Other solutions??
As allways, all suggestions gratefully recieved.
Clive Whittfield
Auckland
New Zealand
RV6, Firewall forward
