Old 11-12-2009, 10:11 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Question OK to remove this much material from forward fuselage rib?
OK, so Stein talked me into moving my radio stack to the left, and that means I'm gonna have to trim off some of the center fuselage rib. I've already removed and reinforced some from the left and right ribs (but I think they are likely stronger than the original).
I'm just a bit concerned about the center rib since it is obviously more structural with the big piece of angle, doubler plate and windscreen/roll bar attach point that Van designed in.
Here is the pic showing what I'll have to remove:
The rack shown is for the audio panel (mounted 2.0 inches down from the top of the panel). You can see in the picture that I'll have to remove some of the flange of the rib. I won't have to touch the angle or doubler plate, so it is my thought that I'm not removing any strength. I could drop the radios about 0.5 inch and clear the rib, but then the transponder is getting awful close to the throttle quadrant....
Below the audio panel is a GNS430W that may just intersect the flange of the rib again, this time on the forward side of the sub-panel.
So, experts, will removing some of the flange of rib be acceptable?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 11-13-2009, 05:47 AM
pierre smith's Avatar
Default Yes....
...many of those have been cut way more than you show. Simply rivet a doubler or piece of 1/2" angle back, parallel to the new edge.
The best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
