Old 11-11-2009, 02:56 PM
odlee odlee is offline
Default Vans "An Aerobatic Epistle", 1998
Is there a copy of Van's Rvator article on this forum? I thought I had bookmarked it earlier, but no luck. Nothing turned up on Google either.
David
Old 11-11-2009, 03:28 PM
Ron Ron is offline
Default epistle
Try this...found under safety.
http://www.vansairforce.net/safety.htm
4th one down I think from older issue.
Ron
Old 11-11-2009, 04:18 PM
lucky lucky is offline
Default builder's manual
I'm pretty sure what you are looking for is in the back of every builders manual for a plane that Van's advertises as aerobatic capable.
Lucky Macy
EAA Tech Counselor/Flight Advisor
Old 11-11-2009, 05:06 PM
Default Yep, it's there!
Found in the safety section. Do not know why it did not show up on the search.
Thanks for the replies. I knew it was on the VAF site, my memory was not sharp enough to return to the appropriate section from 2- 3 years ago!
Regards,
David
