11-10-2009, 12:07 PM
Crankshaft Flange Runout
After searching the net and finding no joy, decided to ask this question at the ultimate authority, VAF!
Does anyone know the flange runout limits for an (I)O-360 AIA? Oh, and maybe a link to the source?
Thanks all,
Jerry
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Reason: Clarification
11-10-2009, 12:52 PM
IIRC the source of this info is Lycoming's Overhaul Manual
however, don't remember off of top of my head what the runout value is..
Radomir
RV-7A sold
11-10-2009, 05:09 PM
Thanks all,
Jerry
Don't have a source to direct you too but from memory I think the max is .002" and the max. that is repairable is .018".
Scott McDaniels
Hubbard, Oregon
11-10-2009, 05:30 PM
The lycoming manual I have shows manufactures Crankshaft Prop. Flange Run-Out min / max as .002 but then list service max as .005. There are also instructions in the manual for checking the run out and allowable limits that can be corrected. If you wish I can email you a copy of the page from the manual.
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 sold
RV-8 Flying
RV-14A building
11-10-2009, 05:35 PM
Table of limits
Yes the source is the Overhaul manual 60294-7. In the back is the "Table of Limits. It says .002 as the mfg. max and .005 as the serviceable max.
I read that to say if it's .005 or less you can fly it.
I didn't see anything about how bad is non-repairable. The shops that repair cranks will know the answer to that one.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
11-10-2009, 07:59 PM
.005" is it.
The reason I know is my crank dialed .070". Anyone want to buy a slightly used O-290-D2?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-10-2009, 09:23 PM
Originally Posted by N941WR
.005" is it.
Yea, the crank in the engine on the wrecked 6A I rebuilt dial about .090 " runout. You could see it was bent just looking at it from the side.
I am pretty sure the repairable limit is .018 ". The face of the flange is surface ground to resquare it to the crankshaft center line and then the flange is re-cad plated (all this only done after the rest of the crank has been inspected for damage of course).
Scott McDaniels
Hubbard, Oregon
11-11-2009, 09:20 PM
SB 201E is the answer
Does anyone know the flange run out limits for an (I)O-360 AIA? Oh, and maybe a link to the source?
Thanks all,
Jerry
Jerry,
This is all detailed in Service Bulletin 201E. I'll shoot you a copy off list. There is also a minimum flange thickness, which varies according to model.
Charlie Kuss
PS If it can be fixed, Aircraft Specialties will charge $210. See
http://www.aircraft-specialties.com/mach.html
Reason: Added PS
11-12-2009, 12:49 PM
Thanks to all who replied. I also noted in my Superior OH manual for O-360 that it says max "Crankshaft Flange O.D. Run-out" is 0.0050 T.I.R., anyone know what "T.I.R." is?
Jerry Cochran
Sherwood, Oregon
Mark Twain
11-12-2009, 12:57 PM
Jerry,
I believe it means "total indicated run out". You generally check this using a dial indicator. I own one that has an assortment of screw on ends. One end contains a wheel, making it perfect for checking crankshaft flanges and brake rotors.
Charlie Kuss
