Different tip-up latch
I was talking with another VAF member and two time offender about the RV tip-up latch.
He does not want to install the scissors type latch that goes through the side of the fuselage. Not even the larger aftermarket one, which he has bought and not installed.
Others must have made the same modification while building. If so, what did they do and how.
We have seen one twist lock in place of the scissors device but that leaves us both cold as you would have to swing a long lever on the inside of the fuselage, which might get in the way of his planned Classic Aero Designs Aviator side panels.
Suggestions, ideas?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
