Old 11-09-2009, 09:50 AM
Sid Lambert Sid Lambert is offline
Default Interesting COMM/Intercom issues
The whole listening to music in your airplane has me thinking of an issue in my airplane I'd like to resolve...
I have a Valcom 760 comm and a DRE intercom. When I plug my iPod in to the DRE on the ground the music is a good volume but as soon as I take off the volume goes down like it thinks ATC is talking to me. It doesn't matter where I set the squelch for the intercom.
Another kicker to this is I bought a Zulu headset last spring and plugged my iPod in to it. I have exactly the same issues even with the intercom turned completely off (switch). I can disable the soft mute on the headset and it works fine so the headset thinks ATC is talking to me as well.
The comm has no squelch but I can definitely tell when I am receiving and when I am not. I have tried 2 different Valcom radios and they exhibit the same symptoms.
Is this just a noise in the system issue or is it something that I am missing?
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 11-09-2009, 09:53 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Have you tried another music source???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-09-2009, 09:58 AM
I have tried an iPod and iPhone. Same results.
Sid Lambert
RV-7 Sold
Old 11-09-2009, 12:50 PM
647jc's Avatar
647jc 647jc is offline
Are you sure the microphone is not tripping or squelching the music. Cockpit noise goes up dramatically in flight and may be causing the music to be squelched. Might try holding your hand over the mic in flight to see if that might be the cause or maybe you have already tried that.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 11-09-2009, 02:36 PM
With the intercom off you can yell in to the mic and it won't come on until you key the comm/mic.
Sid Lambert
RV-7 Sold
