You could, but why?
My 7 kit was made right after the switch to the pre-punched, so I didn't have to jig the tail. But my drawings for the wing stand show 114" between the posts. Your drawing may show something different. If I remember correctly, Van's originally had you build the empennage jig so it could be used for both the HS and the wings.
While you might be able to put the skins on the wings with the vertical posts closer together, I'm not sure what you'd gain by this. If your work area is so small that you can't fit the posts at the suggested spacing, then you're quickly going to hit a roadblock in construction.
I wouldn't worry about wood warpage too much. Bring your wood inside and let it dry before you mount it. After your tail is done, you can check the whole jig for square again and adjust (bend) the wing jig mounting brackets you'll make if needed.
David Welsh
Beaumont, TX
RV-7 N413WD
