If un-grounding the shields worked then great. No problem. However, it's possible that your inverter (nasty noise makes) ground is energizing the airframe and to your shield?. Big noise makers are tough to isolate. You may try installing a Condensor in the path to ground from the inverter. I have been out of the R&E loop for a lot of years so, there are some that probably have better solutions.
Tony Phillips
N524AP, RV 9 (tail wheel)
