Old 11-06-2009, 10:35 AM
PaulR PaulR is offline
Default Canopy Question
I've got my canopy all fitted and drilled and no cracks! The question is about the f/g fairing in the front. I've seen where people have painted the inside of the canopy black and others have used black pigment to dye the epoxy.
After reading the note from Scott at Van's about the wetting issue when using pigment, I'd like to paint the inside. To that end, can any kind of paint be used without worry of the plexiglass crazing or cracking?
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 11-06-2009, 10:20 PM
Greg Arehart's Avatar
Paul,
I didn't dye or paint the fiberglass (I have a tipup) and don't really notice it at all even though it is basically white. I did put a piece of black fabric on the deck inside. I don't think it is necessary to paint or dye, but that's my opinion.
greg
Greg Arehart
N 7965A
Old 11-06-2009, 11:35 PM
David Shelton's Avatar
David Shelton David Shelton is offline
Default Gel Coat
Sounds like a job for black gelcoat. Brush it onto the canopy and let it get tacky for 45-60 minutes. You can proceed when light finger pressure leaves a fingerprint but no gelcoat comes off on your finger. When you reach this stage, start laying up your fiberglass. The two will cure together for a good bond.
Just make sure you do a little homework to make sure you pick a gel coat that is compatible with your resin system. If you want, you can layup a test sample on a scrap of plexiglass.
Old 11-07-2009, 05:27 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default carbon fiber cloth
Another way to do it is to make your first layers with black carbon fiber cloth. I just laid mine up with BID cloth, and it looks fine, but I saw another fairing done with carbon, and it looks real nice.
Also, West makes a black pigment that you can put into the epoxy. See their website. www.gudgeonbros.com
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 11-07-2009, 05:33 AM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default Resin Tint
I used some black tint in my resin. It worked out even better that I had hoped for. The windscreen has been in place now for almost three years now.
It has a niced finished look from inside the cockpit. I would not hesitate to use this method again.
I hope this helps you.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 11-07-2009, 09:29 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I taped the windscreen well, shot a coat of rattle can flat black on the inside, and it's been good for years. Might have used rattle can primer coat first. Don't remember.
L.Adamson --- RV6A
Old 11-07-2009, 06:15 PM
Default Lots of Help
Thanks, guys for all the help. I hope I have the ability to help someone else someday like everyone is helping me.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Old 11-07-2009, 06:51 PM
Bavafa Bavafa is offline
I did mine with carbon fiber and it looks really good from inside (the portion that you can actually see) and the carbon Firber should be pretty darn strong too.
Mehrdad
RV7A - IO360M1B
Old 11-08-2009, 05:18 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Same here....
L.Adamson --- RV6A
Masked and scuffed the inside before a quick squirt with Rustoleum matt black.
I also mixed some black pigment with epoxy and glass beads as the "glue" that held the edge to the canopy deck. I had a good fit here so the "glue" bled into the joint and formed a neat black - actually dried dark gray - bead on the inside. Once that set up I laminated regular glass/epoxy over the joint.
Jim Sharkey
Old 11-08-2009, 06:02 AM
AltonD's Avatar
AltonD AltonD is offline
Us Dothan builders couldn't get along without you!!!!!!!!!!!
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
