Old 11-06-2009, 07:24 AM
HighSchoolBuilders HighSchoolBuilders is offline
Default Right Elevator completed, But....
After completion, I realize the trailing edge is not straight, it's bending slightly at the end where the rib flange touches overlap with the skin. It's very minor but I don't think it's right.
Another thing I notice is the same area where there are the rib, skin, and counterbalance skin riveted together. It's almost as if too many layers are being riveted together and the tip is bended outward. Hard to explain, hope the photos makes more sense.
Thanks!
Hank
Hank Cheng
RV8 Super Slow Build Kit
Titan IOX360, Catto 3 Blades RV prop, Full Dynon everything + Garmin GTN650
First RV in Hong Kong
First Homebuilt aircraft registered in Hong Kong "B-KOO"
Completed RTW journey in 2016
Built with a group of High School Students
Aircraft donated to the Hong Kong Science Museum
In memory of Michael Tam
Old 11-06-2009, 09:06 AM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Elevator counterbalance wt
The lead counterbalance weight mounts to the INSIDE face of the arm, not on the end of it as shown on one of your pictures.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 11-06-2009, 09:34 AM
I can't get to the plan right now, but do you mean the lead weight should not be "Inside" the fiberglass tip when mounted?
Thanks for the heads up!
Hank
Hank Cheng
Old 11-06-2009, 10:02 AM
jlfernan's Avatar
jlfernan jlfernan is offline
No, he is right. See below. On the 9 it mounts inside.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 11-06-2009, 11:47 AM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
Default Hmm...
Hard to be sure from the one pic, but it looks ok to me...
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 11-06-2009, 01:51 PM
rv9av8tr's Avatar
Default -8 is different
Interesting.... I didn't realize the -8 was different...
2017 Paid
Old 11-06-2009, 03:41 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Ummm........
I hope the -8s not different because that's how I built mine.
By veetail88
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 11-06-2009, 04:49 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default The older kits....
....had two bigger weights mounted either side of the horn center web. Moving the weight forward and letting it spread into the volume of the tip fairing allows a smaller weight overall but with the same balancing effect due to the longer moment arm. RV evolution is a beautiful thing
Jim Sharkey
Old 11-06-2009, 07:49 PM
Thanks guys. How does the bend/twist looks, is it fixable, I am concerned because it's an aerodynamic surface. I built everything by the book so far so I don't know what did I do to allow that to happen.
Thanks!
Hank Cheng
Old 11-07-2009, 07:23 AM
flion's Avatar
flion flion is offline
It's difficult to diagnose remotely but ... it looks like some multiple factors got you. From your other thread, you may need to address the trailing edge bend. This is not easy to redress once the structure is in because the structure itself interferes with further bending. Another factor is that it looks like the flanges of the tip rib are not 90 degrees to the web. When fluting, you have to make sure the web lays flat and the flanges remain at the proper angle. Yet another factor might be the attachment of the tip rib to the spar; I think the ribs are symmetrical but could you have canted the rib slightly ... maybe when drilling and installing the elevator horn? That last is about the only thing I can think of that would really cause your problem; otherwise I'd expect the skin to twist the skeleton to fit.
For corrective action, I'd say carefully drill out the inboard tip rib and enough spar to allow you to remove the horn and rib. At this point, see if the skin goes back to a straight trailing edge. If not, you'll need to work the skin to get it straight again. While keeping it straight, reinstall the rib (I'm going to suggest a replacement rib because I think you're going to have to rework it so the holes won't line up anymore; ask for an unpunched rib). Make sure the flanges are 90 degrees and don't push it so far back to the trailing edge that it makes the skin bulge as in one of your pictures. If necessary, remove the flange for attachment at the spar and replace with a bit of angle to allow the rib to be located forward (the strength at that joint is in the elevator horn anyway. Once the rib is in with the skin straight, then drill the horn, being careful not to twist the elevator. The weldments aren't exact due to the welding process anyway and some allowance is made when aligning the elevators later so don't worry if the best fit of the weldment is not perfectly centered in the rib. If I am right about the cause of the problem, that should take care of it with minimal effort and cost.
Edit: I noticed that the bulge at the rib I mentioned is at the outboard tip (6th picture), though I'd still look for it at the inboard rib, too. For the outboard rib, short of reworking the rib and counterweight, you could try enlisting the help of a body man to work the bulge down. It's delicate work, though, and the bulge is not that bad as long as there is no twist there, so you could just leave it and forget it. I've seen worse ... on my own project. Building my -6A was a learning experience that I'm now applying to the -10. But the -6A flies great even if it is a little rough.
EAA Technical Counselor #5357
