11-04-2009, 08:23 AM
Need Help in Atlanta
I'm having an unusual mag problem. Plane currently at KFTY (Charlie Brown) in the Atlanta area. I am on a long trip out of San Diego!!
The mag runs great when cold, and when airborne, but just after landing the engine runs rough, and when I do a mag check, the right mag runs extremely rough, and the engine dies. Two hours later, (After cooling off?) running good again.
I'm having my spare mag shipped overnight to arrive this afternoon, Wed 4 Nov. I have a few tools, but could use a mag timer box, etc.
The mag is a Slick 4370, non-impulse. My spare is a 4371, with impulse, so not sure it will fit.
I could fly to another airport in the area, if that would help. If anyone has a 4370 that I could borrow until getting home to San Diego, that would work, also. Or maybe there is a good mag shop in the area?
If anyone can help, please call my cell: 858-395-7383.
Thanks...
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
11-04-2009, 08:33 AM
I am up at Cartersville (VPC) and have tools and a timing box. I don't have a mag but I'll keep looking.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
11-04-2009, 08:50 AM
No it won't fit, just like that... IC mags need a different gear, a spacer, and longer studs... so I think, unfortunately, you ordered a wrong thing..
Aircraft Spruce isn't that far away.. you could probably drive down and have a correct mag in hand today..
Radomir
RV-7A sold
11-04-2009, 08:52 AM
OK VAF gurus.
I'm thinking he can take the gear and spacer of his 4370 and put them on the 4371, thus removing the impulse coupling and that will work fine. Is my logic flawed?
Sid Lambert
RV-7 Sold
11-04-2009, 09:05 AM
Or he could just order a P-mag and be done with that antique mag thing.
Pete, it sounds like your old mag has a crack that expands when it gets hot, impacting your timing.
Good luck with the repair.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-04-2009, 09:16 AM
You are very close to Aircraft Spruce at KFFC. They are on field and have parts right there.
Kahuna
6A, S8 ,
Gold Hill, NC25
11-04-2009, 09:32 AM
Originally Posted by Sid Lambert
OK VAF gurus.
No, mags with an impulse coupler have a longer shaft.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
11-04-2009, 09:37 AM
You could fly there and I believe there are some RV builders on the field there also. There is at least one RV-10 builder there.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
11-04-2009, 09:53 AM
Definitely RVers on the field
You could see if Vern could help
Vern Darley
Falcon RV Squadron
KFFC Hanger D-30
Peachtree City, GA
www.falconrv.com
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
David Taylor
RV-7 N207DT
Wings
Warner Robins, GA
"The greatest mistake you can make in life is to be continually fearing you will make one. "
Elbert Hubbard
11-04-2009, 10:02 AM
If you can get it to FFC and have a mag, I'll be glad to assist. Spruce is on the field. 770-460-1006
Jon Abarr
