Old 11-03-2009, 11:09 PM
carl nank carl nank is offline
Default DAR Inspection Questions
I read the forums and learned at lot about DAR Inspections, but I have a couple of questions:
1. I read FAR 91-205 and found out that an ELT was not required during the flight testing. My reason for waiting is that I did not want to purchase the ELT yet, waiting for the ACK 406,GPS to be released at a more reasonable price. The DAR said that was true but, he would have to come back for a phase two check when the test flight was done. Is this correct?
2. I have a GNS 430W, GNS 327 transponder, Dynon D100 EFIS & D10 EMS. Will there be a problem getting an IFR signoff with this system and will I be required to have a phase two inspection for IFR?
Thanks for your help.
Carl Nank
Western KY Lakes Region
N39CN
RV7-A, Superior IO-360, 180HP, Hartzell, Dynon D100, D10 & HS34. Garmin 430W & 327 xp. PS Engineering 8000B audio w/3 light marker beacon. Approach Avionics Pro Hub.
Cut Instrument panel myself. I installed avionics myself. Panel is powdercoated a beautiful dark blue crackle.
Old 11-04-2009, 05:18 AM
noelf noelf is offline
Answer to #1 is totally up to you. I went the low(er) cost 121.5/243 route knowing that this was not going to be satellite monitored. It meets the airworthiness requirements for the inspection (and flight), and I can change it out later. Just one less opportunity for the inspector to question the aircraft.
#2...you do not get an IFR sign off on the a/c. To fly IFR, the FARs state the minimum equipments that are required. First is VFR day, then VFR night, then the additional equipment for IFR. Your initial Phase I flight testing will prohibit IFR flight, so the initial IFR requirements do not apply, although you will need to verify / validate that if you are going to fly IFR, you are responsible for meeting the requirements. That will include the equipment, functionality, updates, log book entries, etc.
Old 11-04-2009, 06:16 AM
Fearless's Avatar
Fearless Fearless is offline
Default Sent you a PM
I sent you a PM to find out more about your DAR.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
