Old 11-03-2009, 08:13 PM
sirlegin's Avatar
sirlegin sirlegin is offline
Post Road Hauling
What methods of transporting your plane to the hangar did you use?
I have a street with a tree canopy over it so I must keep the "rig" relatively low.
Any thoughts?
Old 11-03-2009, 08:22 PM
Ironflight's Avatar
VAF Moderator / Line Boy
If "low" is what you want....I used a trailer supplied by a friend who belongs to an antique fire truck club, and uses it to transport trucks to shows. The trailer was wider than the usual flatbed trailer - wide enough for the -8's gear stance. Sat very low to the ground as well.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-03-2009, 08:52 PM
tturner tturner is offline
Default Transporting an RV-6
Here is what I did.
http://www.vansairforce.com/communit...ad.php?t=41007
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 sold
RV-8 Flying
RV-14A building
Old 11-03-2009, 09:28 PM
Jim P's Avatar
Jim P Jim P is offline
This worked great for me..http://adap.com/rv7/IMG_1289.jpg, but it wouldn't work with a -A model due to main gear clearences.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 11-04-2009, 09:40 AM
trib trib is offline
Default U-Haul
I transported by 6A to the airport in a 26' U-Haul trailer. Total bill was about $85. I liked this due to the airplane being in an enclosed environment instead of on an open trailer or liftback wrecker. I only took the fuselage and wings as the remaining parts were easy to take in my Honda van. Whatever you use, when you build the ramp the nosewheel ramp needs to be shorter that the others to maintain the same attitude on the plane as you progress. If equal lengths, you'll discover that the tail will hit the ground before the main gear begin up the ramp. Guess you can figure how I discovered that. If you make the lengths such that they are all contacting the wheels just before the airplane starts up the ramps, you'll keep a good attitude. I used 2x10" lumber with 2x4 side rails for rigidity.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
