Another way
I just built two sawhorses slightly shorter than the bottom of the fuselage at the firewall. Put one on either side of the fuselage. Pushed down on the tail to tilt the assembly up in front, and had a helper slip a 4 x 4 across the two sawhorses essentially under the firewall. One can relatively easily slip spacers on either side of the 4 x 4 to level the fuselage laterally. Then put a sturdy table under the tailcone and lifted the tailcone to put spacers on the table so that the fuselage was level longitudinally.
Another alternative is to build the wing jacks that have been described in several threads. I now have a set of these for changing tires etc.
greg
Greg Arehart
N 7965A
