Old 11-01-2009, 07:12 PM
cjensen's Avatar
cjensen cjensen is offline
Default Thor tail light/strobe?
Does anyone have one of these to report on? I did a search on them, and the most recent post on them is 2007.
I like the Posistrobe and Suntail, but I'm having a real hard time with the prices...
Any Thor's out there?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 11-01-2009, 07:52 PM
Brantel's Avatar
Brantel Brantel is offline
Chad,
I bought one of these:
http://www.kestrobes.com/heads.htm
Round COMBO Taillight with LEDs & Strobe Weight: 4 ounces, Exposed Height: 1.4", Mounting holes are 2" on center and a 1.4" center hole, Mounting configuration: Vertical or Horizontal
Wire & mounting hardware included.Strobe driver not included.
TL-L/S $$130.00
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-01-2009, 07:56 PM
hydroguy2's Avatar
Originally Posted by Brantel View Post
Chad,
That's the one I got also
Old 11-01-2009, 08:02 PM
cjensen's Avatar
Awsome! Thanks Brian's!
I would assume that since it's a standard strobe tube, that my strobes n more 606x would drive it???
Chad Jensen
Old 11-01-2009, 08:21 PM
hydroguy2's Avatar
I certainly hope so, cuz' that's what I'm driving it with.
Old 11-02-2009, 09:56 AM
Brantel's Avatar
Yep it will work...Same power suppy in my plane as well.
We are a frugal bunch are we not?
Old 11-02-2009, 10:08 AM
txaviator's Avatar
txaviator txaviator is offline
Default Engine?
Chad,
I have followed your build over the years...looking very nice!
When are you going to fire up the engine for your initial test run?
Take care,
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 11-02-2009, 10:22 AM
cjensen's Avatar
Originally Posted by txaviator View Post
Chad,
Take care,
Hey Gary,
Thanks! It's looking like Spring for a first engine start...we'll see how much I can get done this winter first!
Chad Jensen
Old 11-10-2009, 07:47 AM
cjensen's Avatar
The Kuntzleman strobe has power!
Thought I'd throw a pic out there of the LED/strobe unit lit up. I couldn't catch the strobe flashing, but you can see how BRIGHT the LED's are...and there's only TWO of them!!
Great suggestion for tail light/strobe combo guys!!
Chad Jensen
Old 11-10-2009, 07:49 AM
Brantel's Avatar
Yep good unit. It is a little large but it will work.
Never did take it apart but can you change the strobe tube in these if it goes bad? Hope so!
