11-01-2009, 04:58 PM
Horizontal Stab Mounting Issues (RV-7A)
Hey - I'm working on mounting the horizontal stab to my RV-7A QB and I'm running into a couple of issues.
1) I'm trying to level the fuselage and the tail. Not sure if this is critical but I figure it can't hurt. The first picture below is a level placed on the longerons in the cockpit area. As you can see, its pretty darn level.
The second picture is a level placed on the 1/8" spacers back on the tail. As you can see, its off a bit (0.3 degrees)
Should I mess around with a thicker shim on the one side to level this out - or is this close enough and nothing to worry about (or is there some design reason I'm not aware of for this difference?
2) When I place the Horizontal Stab on the shims and place the 3/16" spacer to set the incidence, the tail is not level w/ respect to the fuselage. If I increase the spacer to 9/32, the tail is level with the fuselage in the cabin area. I'm assuming that being level is more important than the spacer gap.... If not, please let me know.
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
11-01-2009, 05:34 PM
First I would check that the level at the wing spar carry-through is level with the longerons. The tail should be leveled with respect to the wing. In other words, level the main spar carry-through and level the horizontal stabilizer with respect to that.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
11-01-2009, 05:40 PM
Bingo. Would a water level on the wing attach points be a good leveling solution?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
11-01-2009, 05:48 PM
Sure, that'll work. But wouldn't it be easier just to set the level on top of the main spar carry-through?
11-01-2009, 05:51 PM
Shim as Needed
My RV6 has different thickness shims on either side to level the HS with the wing spar carry through bulkhead.
Jim Sharkey
RV6 - Phase 1
11-01-2009, 06:06 PM
Jim Sharkey
RV6 - Phase 1
Slightly different thickness in mine too. And everything lines up well..............as it's dang fast for a six!
Beats the 9's in fuel conservation too...
L.Adamson --- RV6A
11-01-2009, 06:12 PM
Mel - I just want to make sure I understand what you are saying... I placed a level on the main wing spar. (See pic below). When I leveled this out, the tail/horizontal stabilizer was also level... so I should be good to go if I'm understanding you correctly.
Anyone have any thoughts as to needing a 9/32 spacer under the rear spar of the HS stabilizer to get HS level with respect to the longerons in the cockpit area. Is there a better area to determine level front to back?
Thanks again,
Jason
Jason Tremble
Paid for 2020
11-01-2009, 06:26 PM
Yep, You got it.
11-01-2009, 06:27 PM
Thanks again,
Jason
Since Mel is offline.... edit... Mel is again online
You can't count on the rear deck as being exactly level with the wings. The horizontal stab needs to be (now that you've seen that the fuse is level with the wings) ---- so shim to make it perfect. When you stand in front of the plane, you'll want to see the wings and horizontal exactly parallel.
L.Adamson
11-01-2009, 06:28 PM
Just make sure to check EACH longeron in the cockpit area. If they are not exactly the same level, average them to set up the tail.
