Following Dan Checkoway, I have an ANL limiter between my main bus (at the relays) and the alternator cable. The ANL limiter has orientation markings stamped on the ends. One end says "Ignition" and the other end says "Protected". I assume I put the "Ignition" end on the main-bus side, and the alternator cable to the "Protected end... is this correct?
This is how it appears to be done on another builder's site:
http://rv.jpainter.org/?view=entry&date=2006-06-20#1594 (based on the orientation of the "ANL" and "Mexico" text).
Or maybe this is backwards... current would be flowing away from the alternator, so maybe the "protected" side shoud go at the main-bus side?
