Originally Posted by uk_figs
I have mine hooked up and while it goes to ALT automatically just fine it does not seem to go back to SBY consistently, I think others have had the same issue. I figured the ALT part was the most important so I just live with it.
Sounds like you do NOT have GPS data hooked up but only the altitude data. This is the typical symptom when the GTX-327 does not have the GPS data and cannot "see" when ground speed passes 40 kts. It is using the Altitude data to do the transition form STBY to ALT--the reverse is not so reliable with only altitude data.
