10-30-2009, 07:46 AM
Two Voltage Regulators?
Ever since I installed my brand new lycoming O-360-A1D engine with my old 60-AMP alternator, I've had low voltage problems. The alternator just isn't producing more than 12.5 volts--barely enough to keep the battery charged enough to start the engine.
I've removed the alternator, sent it to the shop for a rebuild, and reinstalled it with no improvment. So now I'm thinking it may be the regulator(s). Last year, I replaced the original 25 amp alternator with a new automotive 60-amp internally regulated one. But I left the old external voltage regulator in place. Didn't seem to make much difference, and the alternator put out about 13.5 volts.
Now with the new engine, I'm wondering if having two regulators is causing me problems. Should I just remove the external one from the system and see what happens? If there anything else i should check?
-Matt
402BD
10-30-2009, 08:24 AM
VAF Moderator / Line Boy
Hmmm....intereating - I never thought about what would happen if you had both an internal and an external VR in the same system. I could conjecture a lot of issues between the two, but that is just speculating based on knowing that the internally regulated alternators do not like having their excitation voltage turned on under a load. The external regulator is probably doing just that - and you could have killed the internal regulator. the only way to know for sure would be to take the alternator in to a shop and have it tested. If it is bad, get a new one, if it's good, bring it home. In either case, I'd try disconnecting the external reg entirely, wire the internally-regulated alternator properly, and see if that works.
I'd say there is a non-zero chance that having the two regs killed the internal one - I don't know the probability, but it is non-zero....
Paul
(Oh, and search for some of GMCJETPILOT's posts on alternators....if nothing else, they are educational!)
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
10-30-2009, 09:48 AM
-Matt
402BD
It would seem 2 regulators would confuse the system, like who's in charge of the charging?
I would remove the external regulator from the circuit, it does not have to be physically removed, just disconnect its wires.
My guess is you will see about 14 volts if the internal regulator has not been assassinated by the external unit in a war over who is in charge of charging.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
10-30-2009, 10:58 AM
Wow... just... wow.
Internally regulated alternators do not make the field wire available for an external regulator to control. The internally regulated alt. needs a control signal to turn it on, and a voltage reference to tell it what to regulate. The two wiring schemes are not compatible.
I suggest you decide between the two alternator system types, and make the wiring correct for the one you pick.
A modern IR alternator should put out a bit over 14 volts. If not, something needs fixing.
Dog is my co-pilot.
Ted Johns
RV9 emp & wings
11-08-2009, 01:54 PM
Removed the External--no change
As suggested, I removed the external regulator from the circuit--no change. I'm still getting at most 13.1 volts.
So do you think it's a bad alternator? How about the battery? It's an Odyssey that's at least six years old--maybe older.
What should I try next? New alternator or new battery--or something else?
-Matt
402BD
11-08-2009, 07:11 PM
I still think that you could have done some damage to the alternator Internal VR by controlling from an external one - if it were me, I'd pull the alternator and take it to an Autozone (or clone) and have it tested.
The thing is, if you're getting more than 13 volts, it's doing something! An old battery isn't going to drag the voltage down unless it is badly shorted.
Paul
Paul F. Dye
11-09-2009, 07:39 AM
-Matt
402BD
If you have a local automotive shop that can test alternators, they will be able to tell you if the alternator is bad. Many internal regulators are epoxy'd in these days making it impossible to repair, so most of the problems with internally regulated alternators require replacement.
11-09-2009, 08:46 AM
-Matt
402BD
If the battery still cranks the engine reasonably well the battery is not your problem.
Is the DMM accurate and trustworthy?
What is the measurement from the alternator case to the output stud?
What is the measurement from the alternator case to the reference pin?
What is the measurement from the alternator case to the negative battery terminal?
Referencing the above measurements to the case is important because there may be bad ground connections.
What is the measurement across the battery terminals?
If the measurement from case to reference pin is an honest 13.1V, then the alternator should be putting out at least 60 amps, trying to raise the output voltage.
Dog is my co-pilot.
Ted Johns
RV9 emp & wings
11-09-2009, 10:17 AM
Those seem like tough measurements to take with the engine running and the prop six inches away. But I did confirm that my local autozone can do a bench test. I'm going to pull the alternator and run it over there this afternoon. If it's bad, I'll grab the popular 87' Suzuki Samurai 55 Amp alternator off the shelf and give that one a shot.
-Matt
402BD
11-09-2009, 01:47 PM
A set of 2 meter test leads with alligator clips puts you well out of harms way.
I like to know what's broken before I start to remove parts. That's what works for me.
Without measurements, it's a guessing game. I'm not a fan of this approach. Finding a bad connector after replacing several hundred dollars of hard parts is annoying.
Dog is my co-pilot.
Ted Johns
RV9 emp & wings
