Old 10-29-2009, 08:34 PM
mbick7077 mbick7077 is offline
Default cut cowling for exhaust 9a
Cannot find any information on how or when to cut the bottom cowling for the exhaust? How much clearance do I need from the firewall? Clearance from the fiberglass cowling? Should the exhaust go straight to the rear or to the side? Vetterman exhaust. Mel
Old 10-29-2009, 09:14 PM
LynnHall's Avatar
LynnHall LynnHall is offline
Default didn't cut mine
I didn't cut the cowling for the exhaust, just for the fit top/bottom and back. It did take a while to get the Vetterman brackets located so that the pipes went down and out the bottom, but for me (o-320) it fit.
Old 10-29-2009, 09:48 PM
Greg Arehart's Avatar
You should not have to cut the cowling to fit the exhaust. It should fit through the opening if you tweak it to the proper position. The only trimming I did was about a half-inch just to clean it up and make the cowl aft edge flat.
greg
Greg Arehart
N 7965A
