Old 10-27-2009, 11:39 AM
bruceh's Avatar
bruceh bruceh is offline
Default Trim tab hinge pin safety wire hole size & location?
Where should I drill the hole for safety wiring the hinge pin? Near the edge of the spar or between the rivets?
What size hole is appropriate and what safety wire size should I use?
Thanks!
Bruce Hill
2020 VAF donator
Old 10-27-2009, 02:43 PM
marchudson's Avatar
marchudson marchudson is offline
Default This is what I did
I put mine between the two rivets and used .032. I probably used .032 because that is what I had. I looked at my plans and they didn't specify a particular size wire so I figure 032 would be large enough. Hope this helps.
Marc Hudson
Houston
RV-7 Sold
Old 10-27-2009, 03:01 PM
roee roee is offline
Default And another option
I secured my pin with a hinge eyelet, which is secured to the spar with a #6 screw and nut. The screw hole is right between the two rivets.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 10-27-2009, 09:07 PM
Scott Hersha Scott Hersha is offline
Drill an .032 or larger hole between the rivets and safety it with .032 safety wire. Should take about 10 minutes (including getting the drill, etc. out) and it's easy to remove in the highly unlikely event you ever need to. Nice job on bending/fitting the hinge pin.
Scott
