RatMan -
The mock-up is the quick-and-dirtiest thing I could throw together to simulate a jack-screw mechanism (as you can see, I invested heavily in PVC & particle board) so that I could do the electrical & software development. The direction of deployment can be easily switched (as you suggest).
Also, the number of flap positions is configurable (up to 4 positions). Several people have mentioned that they only use half and full flaps on their RVs, in which case you could control this system w/ a simple 3-position toggle switch.
In addition, although the video doesn't show it, the flap positions are completely user-configurable in the field. (without using a computer) I should probably do another video to demonstrate that feature.
Brent -
Not an Arduino (but Arduinos are pretty cool!)
Brantel -
Always good to look at failure modes and depending on how the position-sensing pot fails the flaps could do anything from just stop moving thru move to the full extent of their travel. (about the same as what might happen if a microswitch fails in a Cessna)
Rick -
It really comes down to pilot preference, doesn't it? Some people see this as pretty cool (seems especially RV-10 people) and some people just don't see the need. As my dad used to say "To each his own", (which is what Experimental aviation is all about
Thanks to all for taking the time to reply..
