Old 10-25-2009, 05:41 PM
prkaye prkaye is offline
Default firesleeve for wire?
I re-jigged some of my firewall-forward routing to allow for a shorter run from my heat-muff to my heater box. As a result, my starter cable is forced to sit about 2" from my heat muff. I worry that this might be a bit close. Is there any kind of firesleeve or insulation that can be wrapped around 2AWG wire to protect it?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-25-2009, 07:17 PM
N941WR's Avatar
N941WR N941WR is offline
Phil,
Try one of the heat shields that you secure to an exhaust pipe. 2" is a good distance. Don't forget, there is a lot air moving through your engine compartment to cool such things.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-26-2009, 04:56 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Firesleeve
Bill is right, and 2 inches is probably OK for Tefzel cable. To add a little piece of mind, you could slip a little fuel line firesleeve over it. Secure it with a couple of tefzel zip ties, and inspect it at first cowl off after the airplane is flying.
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 10-26-2009, 04:59 AM
what about exhaust-wrap, just in that short section where the wire passes close? I know Vetterman recommends against wrapping his exhaust systems, but I'm only talking about wrapping maybe a 6-inch segment.
Then again, i'm probably worrying about nothing.
Phil
RV9A (SB)
Ottawa, Canada
Old 10-26-2009, 05:18 AM
chaskuss chaskuss is offline
Originally Posted by prkaye View Post
what about exhaust-wrap, used in the racing world? I could apply that to my exhaust pipes to keep the temps down (this was suggested to me by another forum member for the purpose of keeping my cabin-heat air hot).
Phil,
Using exhaust wrap on the exhaust has a down side. It tends to trap moisture against the steel of the exhaust as the system cools down. It acts like a sponge, keeping the steel damp. This will greatly shorten the life of your exhaust system. I suggest you call Larry Vetterman before installing heat wrap on your exhaust system. Using the wrap on the starter cable would be better. The previous suggestion of a heat shield is probably the best idea.
Charlie Kuss
Old 10-26-2009, 05:25 AM
yeah, that makes sense about the wrap being bad for the exhaust.
Can't put a heat sheild there, it's right where my heat muff is. But maybe the heat muff itself will act as a bit of a heat-sheild. The wire sits 2" above the heat muff.
Towards the front i have a similar situation with my alternator wire being about that close to my forward exhaust pipes. I could put a heat sheild there.
Phil
RV9A (SB)
Ottawa, Canada
Old 10-26-2009, 06:12 AM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default The heat muff is cooled continuously
Remember that cool air will always be flowing through the heat muff, so the outer surface of the heat muff will always be a lot cooler than the exhast pipes.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
Old 10-26-2009, 06:18 AM
speaking of which... what about wrapping just the heat-muff, to ensure the cabin-heat air is as hot as possible? It get's cooooool up here in Ottawa.
Phil
RV9A (SB)
Ottawa, Canada
Old 10-26-2009, 07:16 AM
A ceramic coating like Jet Kote would be better. It won't hold moisture against your heat muff. Plus you can coat both sides of the muff.
Charlie
Old 10-26-2009, 07:51 AM
N941WR's Avatar
Phil,
I recommend this. This will not hurt your exhaust and you will have to remove the wrap once a year to inspect the heater muff. So, any deterioration will be caught fairly quickly.
Bill R.
SC86 - Easley, SC
