Old 10-25-2009, 08:12 AM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
Default 430w Screen now need warm up time??
About two months ago my 430w started to only show a partial screen when turned on. If I turned it off it showed the complete screen just before powering of. It takes about 5 minutes to clear out some times and is a pain in the but. I am assuming this is not normal but wonder what others have seen.
This is for the first boot of the day. I am in a heated hanger so I do not expect anything different through winter. The part that concerns me is when I overnight some where and have to tie down outside in winter.
My Trutrak is losing some of its bars too and I was told that several people have had this issue and there is a new screen out?? Not sure if this it true.
I hope I can send them in for a fix this winter.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 10-25-2009, 08:24 AM
bcondrey bcondrey is offline
That is true for the TruTrak. I sent mine in a couple months ago and they swapped the screen for no charge.
Bob
RV-10 N442PM
Old 10-25-2009, 11:47 AM
gbrasch gbrasch is offline
Guest
I use a 430 at work every day and have never seen that on the one I use.
Old 10-25-2009, 02:39 PM
fmarino1976 fmarino1976 is offline
Default Not normal
I've seen one 430 have screen problems before, if I'm not mistaken, on that one, the contrast was really washed out, or something. Garmin replaced the screen for their normal flat-rate GNS 430 repair fee.
A&P, IA, Avionics Tech, and finally: Pilot! (12/28/06)
Dying to build an RV10. Not quite ready yet
Old 10-25-2009, 07:46 PM
TroyBranch's Avatar
Default Stein
Hopefully Stein can chime in as Steinair supplied all the goodies. The units is not much over a year old. Would this be covered in warrenty? Would it go direct to Garmin or Steinair?? Looks like I need some panel down time.
Troy Branch
950hrs Plus
CC EX-2 Flying
RV9 Built and Sold
Dues paid Nov 2019
Old 10-26-2009, 09:11 AM
SteinAir SteinAir is offline
Hi Troy,
Give us a call...we'll see what the deal is. If there are any warranty issues we'll of course take care of them directly for you without any trouble at all!
I'll chat with you as soon as I get a chance.
Stein
