Old 10-22-2009, 06:14 PM
marchudson's Avatar
marchudson marchudson is offline
Default Would you guys fix this or just leave it?
The attached picture is from the trailing edge of the rudder looking forward. The leading edge fiberglass fairing on top of the vertical stabilizer is just a little wider in the center than the fairing on the rudder. After the airplane is painted will it be noticed all that much. Probably not at 200mph but on the ground, I'm not sure how well this will look.
In order to fix this, I would have to lay up a couple of layers of glass then micro on top of the counter weight where it is a little thinner.
Opinions greatly appreciated.
Marc Hudson
Houston
RV-7 Sold
Old 10-22-2009, 06:38 PM
N941WR's Avatar
N941WR N941WR is offline
Are you building a show plane or a go plane?
If show plane, fix it. If go plane, pound on. You will never notice that in flight.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-22-2009, 07:23 PM
bsacks05's Avatar
bsacks05 bsacks05 is offline
I wouldn't bother with it. But that's just me. Probably the only thing to be gained from trying to fix it would be some unnecessary weight.
Build on!
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 10-23-2009, 12:48 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default You asked!
You asked for opinions, so that's exactly what this is. Take it for what it's worth. I am a first time builder having not even started on my empennage.
If it were a question of ordering new, expensive parts from Van's, I would agree with just pressing on. However, for me, I plan on a high level of "quality" or "attention to detail" in my build. Since it seems a simple, all be it weight adding solution, I would fix it.
The fact alone that you are asking, is evidence to me that you strive for a higher degree of quality in your finished product.
Again, this "advice" comes from a first time builder who hasn't even gotten started. YMMV.
Best of luck,
M
Michael
Danville, IN
RV-7A Canopy/Finishing
N317PU Reserved
2020 Dues paid (February 2020)
Old 10-23-2009, 01:42 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Its Your Call
Originally Posted by BoilermakerRV View Post
..The fact alone that you are asking, is evidence...you strive for a higher degree of quality in your finished product...
All you can expect to hear from others on this subject is personal opinion and opinion always runs the gamut from "build on!" and
"good enough" to "nothing less than perfection will do." Opinions really tend to say more about where the opiner is coming from
than anything else. Most builders find a place somewhere between the two extremes of perspective.
Fact is, it is your airplane and this non-critical issue is really a personal one for you to decide. Are you willing to settle...or not?
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 10-23-2009, 02:27 AM
roee roee is offline
Originally Posted by marchudson View Post
...In order to fix this, I would have to lay up a couple of layers of glass then micro on top of the counter weight where it is a little thinner.
That's more of a band-aid than a fix. The rudder is the reference structure, and there's nothing wrong with it. It's the VS tip that isn't contoured quite right to match the rudder, and it's the VS tip that you should fix if you so choose. The fiberglass tips are quite floppy until you bond in an end cap, and you can significantly alter the contour of the tip by how you shape the end cap. That would be the "right" solution.
And in general, bonding fiberglass and fillers over aluminum structure is possible (we do it for the canopy), but it's better avoided when possible, in my opinion. It's prone to future cracking and separation.
Originally Posted by bsacks05 View Post
...Probably the only thing to be gained from trying to fix it would be some unnecessary weight. ...
Actually, I have to point out that added weight would not be a factor in this case. The fix Marc proposed would add weight to the end of the counterbalance arm. So if you were really worried about those few grams, you could drill out the equivalent amount from the lead brick, thereby restoring the original weight and balance of the rudder.
Still, I would agree (yes, just my opinion...) in this particular case forget about it and build on. It's no worse than half the RV's out there, and there are plenty of other more important things to worry about. You can spend as much or as little time as you want to get things a little bit closer to perfect, but since you never reach perfection, prioritization is the key. Very high priorities (things that can kill you): aerodynamic, mechanical, and structural integrity of the airplane. Medium high priorities: weight reduction, drag reduction, maintainability, etc. Somewhere waaaay lower on the ladder: minor cosmetic imperfections.
But I will say this about this particular problem, and in general: if you do decide to take action, do it right. No short cuts, no band aids.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 10-23-2009, 03:52 AM
E. D. Eliot E. D. Eliot is offline
Thumbs up Yes
I am a novice here but I know that every time that I looked at it (preflight), I would wish that I had fixed it 'right' (whatever that turns out to be). You have noticed it and know that it's not 'right' - find out what is wrong and fix it right. You won't be sorry that you took the time to correct it - even if it is only 'cosmetic'. Looks are important IMHO.
Old 10-23-2009, 04:36 AM
unqualified unfluencer
After 5 years of flying you'll have enough hangar rash on the rudder that you'll start thinking about building a new one. Fix it then, IMHO <g>.
b,
d
Doug Reeves (your host)
Old 10-23-2009, 05:01 AM
rbibb's Avatar
rbibb rbibb is offline
From the picture the third rivet head from the rear attaching the tip seems to be protruding 0.001 more than those on either side. Simply won't do. Might cause a local disturbance of the airflow leading to an out of trim condition. Scrap the whole assembly and start over.
Never let the perfect become the enemy of the good. Build on.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 10-23-2009, 06:40 AM
marchudson's Avatar
Default Good one
Thanks Richard that was really funny. I laughed for quite a while this morning.
Thanks everyone for the all the input.
I think I'll wait for the "hanger rash" to develop as Doug put it.
Marc Hudson
Houston
RV-7 Sold
