Old 10-19-2009, 10:46 AM
Bavafa Bavafa is offline
Default Which tire and do I need a new tube?
Its was only six months ago that I finished building and started flying and it looks like I already need a set of tires. My original (Vans supplied) has lasted me about 125 hours and maybe around the same number of landings. A quick search, shows overwhelming recommendation for Desser retread but they have a few different ones and was wondering if any is a better fit/use for RV7A and also do I need to change my inner tube and if so, which one to go with.
Here are some choices available and I would rather not to have to change my wheel pants if I can help it. I believe, I would have to open my wheel pants about an inch with Monster retread but not positive it that is true.
500-5 6 PLY RETREAD ELITE PREMIUM 2 GROOVE
$61.95
500-5 6 PLY HIGH PERFORMANCE RETREAD
$44.00
500-5 10 PLY MONSTER RETREAD
$64.95
Again, thanks in advance for the help.
Mehrdad
RV-7A
Old 10-19-2009, 12:01 PM
guccidude1 guccidude1 is offline
Default Re: Whcih tire and do I need a new tube?
Right off the bat you do not want a 10 ply tire, it will roll like solid rubber. Either one of the other two, your choice and price. I personally use the 4 ply tires, the no leak tubes, and I do not plan on changing the tubes at the next tire change. Changing tubes with each tire change is a debatable subject, some say do change others say don't. There is a good article on this subject on the Sacramento Skyranch web site. Hope this helps, Dan.
Old 10-13-2010, 01:40 PM
dessertire's Avatar
dessertire dessertire is offline
Thumbs up
$61.95
$44.00
$64.95
Mehrdad
RV-7A
Hey not sure if you still need tires, as this is a old post. But I'm going to reply to your post anyways, so in the future you will know which tires to get.
If you're flying a RV-7A
I would recommend the 11/400-5 8 Ply for your nosewheel Aero Classic Tire for $39.95 .
And for your main tires;
500-5 6 Ply Elite Retread
with our leakguard tube
If you have any other questions feel free to ask me, or PM me!
Desser Tires, America's #1 Source for Aircraft Tires
www.desser.com
You can now follow us on TWITTER @DesserTire
Be our friend on Facebook and like our Fan Page; Desser Tires & Desser Tire & Rubber Company
