10-19-2009, 07:40 AM
fuel senders to dynon
I have the float type fuel senders from Vans (Stewart-Werner brand I think). I aslo have a bag labelled IE VMP INSTALL KIT which has a short stainless steel braided hose, some AN fittings some wire and a few otehr things. I plan to use my Dynon D-180 for my fuel gauges. My question - do I need the stuff from this IE VMP INSTALL KIT bag, or do I just run a wire from the connector on each wing tank directly to the dynon?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
10-19-2009, 07:58 AM
VMP INSTALL KIT is for a manifold pressure gauge...
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
10-19-2009, 08:00 AM
IE VMP = manifold pressure
The IE VMP INSTALL KIT is for the manifold pressure.
http://www.vansaircraft.com/cgi-bin/...t=vans-mp-ikit
Just install a wire from each tank to the Dynon.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
10-19-2009, 08:01 AM
Hmm. I wonder why i even have that then. I have a FP prop.
Phil
RV9A (SB)
Ottawa, Canada
10-19-2009, 08:26 AM
Can't answer why you have it, still it's nice to know manifold pressure. It will help if you ever start running LOP to know your actual power setting.
10-19-2009, 08:35 AM
...So you can calculate percent power.
...So you can calculate percent power. Besides, the Dynon does this for you automagically, thus needing outside temperature and manifold pressure as well.
Alfio
> 1,000 hrs tach.
10-19-2009, 08:37 AM
OK. The IE VMP INSTALL KIT says "Caution: teh gauge and sender are not compatible with other units".
I guess what I need for Man press will be contained in my dynon sensor package?
Phil
RV9A (SB)
Ottawa, Canada
10-19-2009, 08:40 AM
I don't remember a sender in my install kit, just the hose and AN fittings. The actual sender is from Dynon.
Alfio
> 1,000 hrs tach.
