Old 10-19-2009, 06:29 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default First Annual Conditional
I built my RV-4 last year. Two questions:
1 - What RV-4 specific ongoing maintenance items are there? Right now I'm checking the firewall for buckling. What else specific to RV-4 should I be looking at?
2 - I've done plenty of owner assist annuals before, but I've never done my own annual from scratch. Where do I check on ADs? Is there an online resource?
-Bruce
RV-4 N254MM Fastback RV-4
Old 10-19-2009, 07:12 AM
N941WR's Avatar
N941WR N941WR is offline
Bruce,
Engine AD's, check www.faa.gov.
RV-4 AD's, there are no such thing. However, Check Van's site and read through all the old RVators.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-19-2009, 11:14 PM
131RB 131RB is offline
Bruce,
As stated above all AD's can be found on the Faa's web site and all service bulletins aplicable to the 4 can be found on Vans web site. Even though AD's and Service bulletins may not have to be complied with its a good idea to figure out whats important regaurding saftey. For example the Lycoming oil pump AD. I have physically seen two aluminum impellers that have failed (cracked in half). I consider this an important AD.
Other things to look for on the airframe.
Cracks in flight control surfaces
Hinges for cracks or loose rivets
Spar areas tail and wings for cracks or loose rivets
Controls IE pushrods for loose rivets tight bearings and possible cracks
from fwd stick tail all points and control tube to ailerons all points.
Wheels, Tires, Brakes, Wheel bearings.
Landing gear and engine mounts for cracks
Engine
clean and gap plugs , check compressions, clean fuel filter if aplicable, clean or replace airfilter, check for exhaust cracking, check under heatmuff for cracks or holes, clean engine, overall inspection for any thing abnormal. These are just a few things off the top of my head.
Ryan RV4
Old 10-20-2009, 05:43 AM
pierre smith's Avatar
Default Two very good habits...
...during condition inspections are:
A) Use a checklist
B) Start at either end of the airplane and work systematically toward the other (an old A@P's good advice). Don't just bounce here, there and everywhere.
Personally, I start at the spinner. It comes off and the safety wire cut on the prop bolts and they're re-torqued. Next is the starter wiring, then the plugs come out,,,etc, working your way backward, oil filter, gascolator, carb drained (very important), all fuel and oil lines checked for security...etc, compression checked, plugs cleaned, mags timed, oil filter changed, cut open and inspected.
When you arrive at the wing spar box after the floorboards are removed, you also then work your way east and west through the pushrod connections, bellcranks, secondary pushrods and aileron/flap hinge checks.
Continue toward the rear checking each inch of controls/cables 'til you arrive at the stab/fin attach points...you get the idea, and each item is checked off on the list as you proceed.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-20-2009, 07:49 AM
BruceMe's Avatar
Great input, I'm taking it all in.
Old 10-20-2009, 08:20 PM
Gary Bricker Gary Bricker is offline
Thumbs up Log Book entry
Is there a generic log book entry for the conditional inspection
Old 10-20-2009, 08:23 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Op Lims
I don't know if there is one for a "Conditional Inspection", but the one that you need to write for your "Condition Inspection" should be on your Operating Limitations....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-20-2009, 09:58 PM
PCHunt PCHunt is offline
Paul
I've been biting my tongue, wondering who would be the first. I thought it would be Mel.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 10-21-2009, 10:12 AM
Thumbs up Texan talk
Thanks for the correction
Old 10-26-2009, 09:57 AM
BruceMe's Avatar
A) Use a checklist
B) Start at either end of the airplane and work systematically snippped...
Thanks, it's working out very well. I used this checklist (it's in the middle of the page)...
http://www.vansairforce.org/POH/RV-4_1/rv4.html
two half-days, one more half-day should do it.
