Old 10-18-2009, 10:09 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Those Pesky Washers-Simple tip
Fellow Builders,
This idea isn't anything new but I decided to post it for those who might have not thought to do it.
There are situations where washers are used center rod ends on the control weldments and bellcranks throughout the RV's. If you haven't experienced trying to get some of these washers in position it can be very time consuming and frustrating.
One very simple solution is to glue them to the weldment. I decided to do this after some very frustrating washer moments.
Even though you may never need to take a pushrod out, or remove a bellcrank, gluing the washers in place will help with the initial installation.
I used JB weld (good stuff) and clamped the washer in place with a bolt while curing. Took a little time but it is well worth it.
Enjoy,
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 10-18-2009, 10:58 AM
AltonD's Avatar
AltonD AltonD is offline
Avery washer wrenches.
http://www.averytools.com/p-242-washer-wrench-set.aspx
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 10-18-2009, 11:02 AM
dsyvert dsyvert is offline
Default Another way
What I have done is use a corner of masking tape on the washer and then lower them into place. It works well for me.
Dave Syvertson
Old 10-18-2009, 11:38 AM
Tbone's Avatar
Tbone Tbone is offline
I use Marine contact cement. It dries quick and can be used on your finger to hold those smaller nuts and to glue washers to the nut. use sparingly.
___________
Terry
RV7
XP IO360
Old 10-18-2009, 01:05 PM
I am guilty of gluing the washers with EZ-lube myself. It's pain in the neck to insert them. My question is - how Big Boys are doing it building certified airplanes? Of course we have rights to experiment but is it approved method by the book? Should those washers have some sort of rotational capability? If somebody has a theory please chime in.
Old 10-18-2009, 04:34 PM
Pmerems's Avatar
Default No rotation required
The washers are in compression and don't rotate once installed. Therefore securing in place (gluing) isn't an issue.
Paul
