Old 10-16-2009, 04:35 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default RV-12 avionics-D180 and Flightcom 403 question
RV-12 builders.
I am using the same avionics in my RV-7A (Dynon D180 and the Flightcom 403 intercom) as van's sells for the RV-12.
Can anyone tell me about or scan the wiring diagram for the audio alarm output from the Dynon to the Flightcom?
Does the Dynon alarm output hook up directly to the Aux music input of the Flightcom? Or does it go through another device?
I am in the process of debugging noise issues and wonder if RV-12 builders are doing something different in the wiring then I am.
Paul
Old 10-16-2009, 04:40 PM
vandi vandi is offline
you may want to repost or have a mod move to the dedicated RV-12 forum.
There is some issues that folks have requested wiring diagrams out of Vans, but so far that I'm aware nothing to the likes.
Old 10-17-2009, 10:17 PM
Ted Farmin Ted Farmin is offline
Default Dynon and flight com issue
Pmerems, I had a similar situation so I called Dynon and then Flight com. They were very helpful and resoved the question.
RV-4 Ted and Tim
408 hours
