Old 10-16-2009, 02:19 PM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
Default True Build Times??
I was wondering if I could get some quick opinions on true build times. The build would be a slow build 7 (hopefully not that slow!), with no paint. I would be a first-timer. In my mind, I am capable enough to get through a build (not a pro but not I have some mechanical skills. I am certainly not afraid of tools.). I can see having to slow down at certain points though, like panel/electrical, which I have no experience with.
I've tried to read as many of the first flight stories on the Van's site as I can, but most people don't describe their prior experience or whether they went with a QB or standard kit, or even if they did their own panel or not.
Obviously this might be a pretty wide range of times, but I am hoping to get a little better grasp of your experiences in the real world.
Thanks!
Old 10-16-2009, 02:57 PM
apkp777's Avatar
apkp777 apkp777 is offline
Hoping to have in done by 800 hours total slow (not QB) build.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 10-16-2009, 03:04 PM
AndyRV7's Avatar
If I were you I would build 2!!
Old 10-16-2009, 03:06 PM
tinman tinman is offline
Plan on at least 2,000 hours. It took me about 2500 hours, but I am slow.
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 10-16-2009, 03:12 PM
apkp777's Avatar
There are lot's of tricks to cut build times significantly. I think if I built another I could shave 10% or more off where I am at right now.
I don't really know how much time I have left, but I have 504 hours into it so far.
I admit, I don't enjoy the building as much as other do. I don't fool around, I just knock stuff out. It helps that I worked structures for Boeing and United Airlines for many years.
Tony Phillips
twsurveyor's Avatar
twsurveyor twsurveyor is offline
Default Build Time
I have 4 friends that have completed side by sides (slow builds) recently. All work for a living, hence all are "part time builders".
Don't know the average "hours" but surmize it to say that the average was 4 years, start to finish, for these 4 dudes.
By the way, it's just wrong to refer to the new prepunched kits as "slow builds"!
Tommy Walker
RV-6A (true slow build)
Flying, 470 hours and "Climbing!"
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
There is a lot if variation in tracking hours. I have recorded and allocated actual shop or hangar time omitting travel, computer, research, investigation, and other head scratching conducted away from tools. This time can be extensive. I am closing in on 1,200 hours now and suspect another 400 or so to be ready for first flight without leg fairings or pants.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 10-16-2009, 03:17 PM
apkp777's Avatar
Yeah the prepunched skins are awesome. You RV 6 (and older kits) guys have a lot more work than mine.
I don't track the hours spent researching (and blogging). I do round up to the next hour though (3.2 hrs =4) to sort of account for the time I spend staring at the project in my pajamas.
Tony Phillips
Old 10-16-2009, 03:23 PM
AndyRV7's Avatar
OK, I am starting to feel better. I figured I would be a slow builder because I study things a lot and then go step by step. Pretty methodical by nature. I figured if 2000 was the Vans number I would be 2500-2800. But I was worried that that actually might be 4000. But I haven't seen anyone claim that long of a build, so I feel a little better.
I agree in theory with the head-scratching idea. I can imagine a lot of time in the house trying to figure things out.
Old 10-16-2009, 03:32 PM
apkp777's Avatar
You can save a ton of time by studying the whole set of plans and drawings and working it out in your head how everything goes together.
When I get a chance I will post some of the things I have done to cut my build time significantly.
For now, plan on having a complete set of tools, buy one of EVERYTHING and two of MOST. You can always sell the stuff later.
When I worked for Boeing I would always have at least 4 drills chucked, 2 or 3 rivet guns, and several pairs of cleco pliers. You would be surprised how much time is spent changing drill bits.
If I built another I would make all the brackets and angles for the entire kit all at the same time, mark them and have them ready when the time came to assemble them.
Tony Phillips
