02-21-2010, 07:16 PM
Wing tips and prop tips!
Originally Posted by Mike S
I saw that prop too, on a race plane at Reno-------kicked but t on the rest of the field big time----like 30 mph IIRC
It sure did! That's one of the ones I designed for Tom Aberle and JeFF Lo. If you think those tips were rad, you should see the ones I designed for Tony Higa's racing Pitts, my new three-blade, and the way-out tips on two Reno T-6 racers. And no patented T-6 noise. With these props a T-6 is no longer the most efficient way to convert av fuel to noise!
The new Boeing designs now feature a longer triangular extension. I think the 737-800 or -900 as well as the 787 have them. No more turned up tips.
02-21-2010, 07:41 PM
Paul,
(Sorry for straying off topic here). But for the eternally curious, would you mind sharing a few pics of those wild props you designed for the T-6 racers and Tony Higa?
George
02-22-2010, 12:43 PM
Here are some pics of my designs. http://tinypic.com/4dukursz
Reason: To show link
02-22-2010, 03:02 PM
Looks like the pictures didn't come through, elippse. Can you try again?
Rob Prior
02-22-2010, 05:04 PM
Tips, wing and prop
"Guess I don't understand the process yet. I went on tinypic and downloaded the pix, got the URL, and tried to put them on the forum, but just a frame came up with the little red x in the upper corner. So what did I do wrong?
02-22-2010, 05:20 PM
Go to where you uploaded your image and right click on the image itself. Click "Properties", then copy the address. On the posting box, click on the mountain picture and paste the address for your image. Result will link directly to the image:
Ryan Winslow
02-22-2010, 06:14 PM
Senior Curmudgeon
As above, only first click the thumbnail you want to put up, then when it expands, right click and choose "copy image location", then paste that into the window the yellow sun icon opens up.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-22-2010, 09:32 PM
Paul,
Are these high performance prop designs suitable and/or appropriate for use in everyday flying, and if so, are they going to be available at some point to the retail marketplace? Thanks.
Will McClain
N954WM (Reserved)
02-23-2010, 01:22 PM
Props
Originally Posted by WhiskeyMike
Paul,
Hi, Mike! We're getting a little off-subject here, but I design props for experimentals. Please contact me at elippse@sbcglobal.net. Thanks! Paul
02-23-2010, 02:28 PM
move to propellers
I thought it would be better to move any propeller discussion to the propeller section and I posted a new thread called Rad props and I tried to insert an image but when I put in the URL, all I got was the URL printed on the thread.
