Hi John.....
....the problem is that there's a small tab left that keeps the switch body from turning. You drill a smaller hole than you need intially, the edge of which just touches the inner end of the tab. You then overlay the backing plate of the switch and trace the opening and finish filing either side of the tab to dimension, so I can't give you a hole size.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
