  #11
Old 12-22-2011, 07:17 AM
Mel's Avatar
Mel Mel is offline
Originally the RV shoulder harness used seat belt material further back into the tail-cone. The reason for the change was elasticity. The seat belt material had too much "stretch" and made the shoulder harness essentially ineffective.
Mine are stainless and don't seem to affect my compass module at all.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-22-2011, 08:25 AM
Danny7 Danny7 is offline
mehrdad try these guys, they should have some stainless cable you could use.
http://www.acmerigging.com/
it is used a lot for railing restraint, called decorative but there shouldn't be a problem finding proper strength sizes
nothing special here...
Old 12-22-2011, 09:07 AM
jjconstant's Avatar
jjconstant jjconstant is offline
I went through this process for a different reason. I used inertial reel shoulder harnesses and the inertial reel needs to be mounted securely so that there is no slack in the entire system. The standard Vans cables were too long and would have flopped about midway between the baggage bulkhead and the seat back, providing so much slop that the inertial reels wouldn't have locked until after my face was through the panel
I called Vans and they suggested that I go to a marine rigging place and get some stainless cable and have them cut it and swage it to whatever length I needed. That's what I did. My magnetometer is also back there and there are no issues.
All Best
Jeremy Constant
Old 12-22-2011, 09:47 AM
Dyneema rope will do well. It's a low-stretch marine rope used on sailboats and other applications. Although it's low-stretch, it still stretches more than wire rope. The numbers for Young's modulus are about 4 or 4.5 million psi for the Dyneema and about 11 or 12 million psi for the steel cable, so if you double the nominal diameter for the Dyneema, you'll be okay for low-stretch.
And Dyneema's strength is so great that it simply won't be an issue. It's very light. I think it'll float.
The caveats and gotchas are:
1. The Dyneema is slippery and knots aren't reliable. Worse, they'll break at relatively low loads. Only a proper splice should be used, such as this one, which is fun to make:
http://www.neropes.com/SPL_12Strand_...ceBrummel.aspx
Personally, I can't splice this if it's thinner than 1/8" thick, and that's difficult. Thicker is easier.
Incidentally, the buried end needs to be well-tapered and buried at least 44 times the diameter. The easy way to taper it is to bring it out of the cover (bunch up the cover) below where you want the end to be, cut the taper on the individual strands, and then pull the cover back over them.
2. The Dyneema is sensitive to stress concentrations and won't develop its strength around sharp edges or small radius objects. Ideally you need something like 8 times the rope diameter for the diameter of the object the Dyneema is wrapping around. Smaller gives proportionally lower strength, and since the rope strength in the oversize diameter is high, you might be able to get away with it in some applications.
3. Dyneema creeps. If there's a steady load it'll gradually stretch. You wouldn't use it for control cables, for example, since they generally need tension.
4. It's pretty abrasion-resistant and fairly UV resistant. In both cases it'll wear or soften on the exposed fibers and you can see and feel that. But it's not as durable as wire rope in that regard.
5. Being a low-stretch rope, it doesn't absorb much energy when loaded. You would not want to use it for climbing, for example, if you fell, the shock would be very severe.
You can get Dyneem from places like http://www.apsltd.com/c-1492-amsteel-blue-samson.aspx, under the trade name "Amsteel Blue."
It's good stuff, when used with knowledge of its characteristics.
Dave
Old 12-22-2011, 10:18 AM
jchang10 jchang10 is offline
I have been trying to calibrate my dynon skyview compass without success. My best guess now is that my steel seat belt cable is the culprit. the adahrs/magnetometer lies about 8" above the steel cable.
Update: well, i removed the cable and am still getting the darn error. i seemed to have ruled the cable out.
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 12-22-2011, 11:20 AM
JSBergen JSBergen is offline
I asked a similar question about a week ago but due to the trim cable location on an RV9A relative to the Garmin GMU-44. I have been told that you can demagnatize the cables (degausse) sp? either with a permanent magnet or with an electro magnet. I am still researching......
Regards,
Jamie
Old 12-23-2011, 12:52 PM
Jef Vervoort Jef Vervoort is offline
Default non-ferrous type cable
Thanks for that info, Jchang, I have also two Skyview Adarhs in the proximity of the cables, at about the same distance. I'll try to calibrate with the Van's cables.
Old 12-23-2011, 12:56 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I was at West Marine today getting some supplies and found that they will sell you SS wire rope and swag the fittings on in the store! Here is the link to there catalog page.
http://www.westmarine.com/webapp/wcs...classNum=50090
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
