Originally Posted by avantveld
Hi all,
We just started with the rebuild of a RV7A that recently suffered a nosewheel collapse and rollover. The (wooden) MT prop luckily absorbed most of the forces....PH-VII, RV7, flying
The nose gear bottom two brackets/mounts take most of the forces in a nose over- Don’t ask me how I know!
Though our 6A did not go all the way over. We did see some de-formation in that area.
The bend of the nose gear will give you a clue as to how much force the firewall may have had to sustain. In our case the bottom of the rudder was smacked up. In your case it may have been the top rudder/vertical.
Also we removed, stripped, and sandblasted the engine mount for magnaflux inspection.
Stripping the powder coat was the most fun!
Our A&P also inspected the fuse and rear tail bulkheads by flouresent lights and measuring the cross sections of the bulkheads.
FWIW
