LOE ECI discount & Prop Balance up for bid
Here's my LOE winnings from Rosie's list:
BIG WINNER - Prop Balance and 25% discount on New Titan EXP Angle Valve Cylinder Assemblies from ECI (about $600 off list per unit)
Highest bidder with a check made payable to one of the charities listed above (or split between them) gets the prize! You can bid on the Prop Balance, the Cylinders, or both. Whichever bid or combination thereof that generates the largest donation is the winner. Bidding starts now and ends Wednesday 7:00 pm CST. Please use PM to register your bid. Dig deep... it's for a good cause!
Prop Balance Update - from Ferrer Aviation:
Congrats on winning the Prop Balance. I believe I (Ferrer Aviation Services, LLC) am the donor of that item. I just wanted to advise you, or whomever ends up with the certificate, that I will be in the Bahamas during the rest of October and all of November and will be unable to do any propeller balancing work during that period. The good news is that the certificate doesn't expire and it is transferable. Please pass this information to the next winner.
Have a great day!
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
