Old 10-12-2009, 07:38 AM
rv7charlie rv7charlie is offline
Default -7 tipup seat back/roll bar interference
I remember seeing some discussion of this many months ago when I discovered it after building my seat backs, but I can't find any posts using the search engine (too many hits).
How did you cope with the interference? Move the entire seat back inboard (mine would need to move ~1/2"), or trim the outside edge of the adjuster?
Charlie
Old 10-12-2009, 07:43 AM
Brantel's Avatar
Brantel Brantel is offline
Move it... Everyone will notice you notched the angle adjuster but if you have an offset hinge, nobody will ever see it.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-12-2009, 07:53 AM
That was quick. :-)
No issues with the effective seat positions being an inch closer together, & having the sticks offset a half inch between your knees?
Charlie
Old 10-12-2009, 08:02 AM
Brantel's Avatar
The plans are easy to misread on where to put the hinges on the floor pans. If you do it wrong, the seats will hit the rollbar. If you do it correct, they won't.
Tons of people fall in this trap.
Move it over till the adjuster just clears the bolt head on the roll bar and you will be fine.
Old 10-12-2009, 09:57 PM
Yeah...Brian is *sorta* right. :-) When I built them, everything fit. When I added the roll bar, they no longer fit. (7/8" on the seat bottom hinge halves, per plans). Moving the seat backs over enough to safely clear the roll bar & bolt heads means that the inside edge will hit the flap cover mounting flange at the bottom when the back is tilted forward, but that only happens with it pinned to the middle position. Also, the seat backs are no longer centered on the control stick cutouts, but that can't be too big a deal.
Oh well, it's only one more day wasted. Actually less, if I subtract the hour I wasted hunting for the gas strut mounting screws that ("oops; sorry 'bout that") aren't listed on the parts list.
Did you guys know that the company that's capable of making the most popular & doubtless the best engineered line of kits on the market can't figure out how to make a computer file out of the computer file they print when they build a kit order?
Charlie
(Thanks, Brian; seat backs have been modified.)
Old 10-13-2009, 06:28 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
anyone have any pics showing this issue?...as it will be coming up in my near future.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 10-13-2009, 06:51 AM
Brantel's Avatar
This is a design flaw but you will not notice it much once you have your seat cushions in as they stop the seatback from being able to fold that far forward (at least not easily).
Old 10-13-2009, 08:22 AM
Ryan, I'll try to snap a couple of pics today.
Charlie
Old 10-13-2009, 08:28 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
the interference is only at the middle hinge and can easily be addressed with a bit of filing... as brantel suggests it is likely not an issue on the pilot side with stick and cushions installed but might be irritating on the co-piolot side if you could not fully fold the seat forward with the stick removed... i have set the copilot seat up avoiding the center hinge and went ahead and relieved the interference on the pilot side... no big deal.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 10-13-2009, 08:30 AM
rzbill's Avatar
rzbill rzbill is offline
Default There is one other possibility
The advice above is all correct. If built exactly to the plans, the seats will clear all obstructions at the top, but hit the flap cover flange at the bottom when folded forward without the seat pads in place.
There is one other aspect that could influence the interferance. When building my seatbacks, I noticed that the corrugated seatback sheet was not square because of variation in the corrugation bends. I did not recognize it until I was done (I actually trimmed some of the angles to fit the seat back sheet). Fortunately for me, this did not affect the seat enough to cause any interferances. However, if the seatback was way off, down at the hinge area, one could theoretically build the seat out of square enough to cause an interferance at the top. This can be avoided by NOT doing what I did. The correct way is to make the seatback angles to the print length and then pull the corrugated sheet to fit the angles. This will pretty much force the overall seatback to be square (or square enough to work fine).
Bill Pendergrass
ME/AE '82
