Old 10-11-2009, 08:30 PM
AltonD's Avatar
AltonD AltonD is offline
Default Weird strobe behavior. Anybody seen this?
I searched the archives and couldn't find anything
My tail strobe is intermittent. It will work for 30-40 seconds, then nothing. A minute later, it repeats. I swapped leads and it stays with the tail strobe so it is not the power supply.
Now the weird part: If I turn the Nav lights on, it works just fine.
Anybody seen this? Bad tube? This is the combo nav/strobe tube.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 10-11-2009, 11:12 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Ground??
Sounds like ground path related.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 10-12-2009, 04:52 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Strobes
Is this the Whelen tail strobe unit? If so, I'll bet you have the ground for the white tail light, and the trigger to the strobe reversed. Check your wiring at the rudder. It is also possible that the strobe unit is wired wrong. check the pin positions on the strobe lamp itself. Never heard of this happening, but it is the only thing that makes sense.
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 10-12-2009, 06:24 AM
AltonD's Avatar
No, this is the three strobe unit from Van's.
I am thinking a poor ground issue. The pwer supply unit is grounded to the frame. I am going to run a test wire to the fire wall ground block and see if that improves. The tail nav light is also grounded to the frame. I did this with all of the lights.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
Old 10-13-2009, 05:28 PM
EFG EFG is offline
I had this problem on a 182RG with Whelen Wing tip strobes. The left one flashed in a pattern that could never be discerned, the right was normal. Turned out to be the strobe bulb was losing gas and the firing of the strobe was more and more intermittent as it got lower in pressure. A replacement of the strobe bulb while expensive, fixed the problem. I never would have guessed this was the issue till I spoke with a guy from Whelen, cause it actually was firing. When in doubt, call the manufacturer !!!
Old 10-13-2009, 05:33 PM
EFG EFG is offline
Oh, I forgot to say, it worked fine if you ran the engine up to 1500 rpm (system voltage change). The guy said they are "voltage range sensitive", range being the operative word here.
Give'em a call, very friendly and helpful.
Old 12-21-2015, 03:11 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default I'm in the same place....
Was there ever any resolution here? Fully assembled for the first time, now I've got the intermittent tail strobe issue. I left it running for an hour, batt+power supply, EFIS said voltage never got below 13.0v. Sometimes a double flash, sometimes a single, sometimes none. No discernible Pattern to it.
It's the three strobe Whelen from Vans. Wiring checks.
Thanks, Rick
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
