I did rivet these a little flatter than the rest but did not have them flush with the spar flange. There is probably enough clearance with a proper shop head, but I didn't want to have to address this again. What you do need to rivet flush is the aft-most, lower rivet thru the skin/704-C/gear mount web. The gear mount will likely interfer here.
