People have successfully used many different techniques, both with and without adhesives, to do the rudder trailing edge. Use the search utility on this forum and you'll find many previous discussions on this topic.
Same goes for just about everything on this airplane. There are many ways to skin a cat. The plans are fairly comprehensive, but their purpose is to show the structure, not any specific technique to use. The manual does suggest some techniques, but that's by no means comprehensive. Your own creativity, and other builders' experience which you'll find on the forums, are an invaluable supplement.
Generally, when you have a question on how to do this or that, chances are it has been asked and answered before. Search the forums, and if you don't find a satisfactory answer, by all means ask.
