Old 10-08-2009, 10:13 AM
prkaye prkaye is offline
Default stewart systems test of time?
One hesitation about Stewart Systems is that I wonder how long the product has been tested in the field. Has their product been around long enough to know whether it will stand up well on an airplane for a decade or more?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-08-2009, 11:59 AM
thallock thallock is offline
I haven't seen any information on longevity, but their gallery shows that at least one airplane was painted in 1999.
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 10-08-2009, 05:35 PM
Erik Westlund Erik Westlund is offline
Default we're in the same place
we were doing research about trying it also. but we're in the same boat as you concerned about how it will hold up. I found a navy test where they did tests with waterbourne paint. which is what the stewart sys is, and the results as far as I can see were that it held up well as far as bonding but it tended to chalk up. we used it on our boats for a short period of time about 15 years ago. diff brand than stewart systems I think was system three cant remember though. anyway we found the same thing it would chalk up on the surface. and we also found out the hard way that water would seep right through it. you could set the boat in the water and watch water seep right through the hull. yikes! like I said though that was 15 years ago, so the chemistry is probably alot better now. but because its still an unknown we're going to use ppg desothane probably the 8800 buffable topcoat.
good luck
Erik
http://www.enviro-navair.navy.mil/pu...actsheet03.pdf
RV7
Empennage done
Wings done
Quick Build Fuse
wiring & finishing fairings
Old 10-08-2009, 06:31 PM
rocketbob's Avatar
I really like Kirker paint. Its an off-brand, sprays nice and is very durable. For about $600 in materials you can do a nice base/clear paint job on an RV.
www.smartshoppersinc.com is where I get Kirker paint from.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
