Old 10-07-2009, 12:58 AM
chiricuca chiricuca is offline
Default Pictures of installation of Blast tube on mechanical fuel pump
Has anybody pictures of installation of Blast tube on mechanical fuel pump? I am a little confused with it and I would like to avoid VL problem. I was reading that some people installed too in gascolator, any picture too could be possible?
Thanks a lot.
Old 10-07-2009, 04:56 AM
Pilottonny Pilottonny is offline
Thumbs up Standard fuel pump cooling shroud from Vans!
I used the Vans cooling shroud: http://www.vansaircraft.com/cgi-bin/...product=shroud
Just put a 1" scatt tube, that is attached to the rear baffle, on it.
By the way, I had to buy 2 m of the 1" scat tube (and paid over € 140,- for it!), so I have quite a lot left and am willing to sell you a piece at the price I bought it for (€ 70,-/m). It is the same fire proof, orange, type of tube that Vans use for the heater. I do not want the cheap Nylon or PVC stuff under the cowling! enough stuff under there that can burn and make smoke already.
If you are interested, let me know what length and I can send it to you by mail.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 10-07-2009, 07:07 AM
TomVal's Avatar
TomVal TomVal is offline
Default Scat tubing for Fuel Pump
This is a sideways photo of the fuel pump cooling shroud and scat tubing:
Scat tubing attachment to aft side of engine baffle:
Cooling air inlet side of scat tubing:
Hope this helps.
Regards,
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 10-07-2009, 07:24 AM
Thank you very much for your help. Now I see clear how to install it.
Regards
