Old 10-06-2009, 02:35 PM
avi8tor50 avi8tor50 is offline
Default Tire inflation pressures for nosedraggers
Hi all-
I know this has been discussed in the past but was looking for some current info. Was wondering what inflation pressures folks were using for the nose and mains for nosedraggers, especially 9A.
Also, has anyone found a better quality replacement tire/tube for the nose?
Peter K
9A in the paintshop!
Old 10-06-2009, 03:09 PM
vic syracuse vic syracuse is offline
Super Moderator
I've been using 50 psi for the mains and nose on my RV-7 for over 200 hours now. Works great. No shimmy, and it's easy to push around by hand. I did balance all wheels with a motorcycle wheel balancer.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 10-06-2009, 04:25 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default Life the Universe and Everything
42 The answer to everything, and what I carry in my mains and nose.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 10-07-2009, 04:50 AM
plehrke's Avatar
plehrke plehrke is offline
I use 35 all the way around. no issues.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 10-07-2009, 04:53 AM
Geico266's Avatar
Geico266 Geico266 is offline
25 PSI all around on the -12 seems to work so far.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 10-07-2009, 06:12 AM
AlexPeterson's Avatar
There is strong evidence that lower nose wheel pressures lead to "cracks" in the sidewall of the tube (see previous threads). I keep a minimum of 35, starting with 45 in mine. A good rule of thumb for preflight checks is that when the corner of the nose tire's tread just makes contact, the tire needs air. This will differ with different nose weights, but give it a try to see where that point is on your own plane.
I think it is better to chase shimmy with break out torque than with lower air pressure.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 10-07-2009, 11:46 AM
LarryT LarryT is offline
Default Published pressure for 5.00 x 5 tire is 50 psi
That is for rated load = 1250 lbs.
While it is true that inflation pressure can be reduced for lower loads, there is a risk of excessive sidewall deflection at low inflation pressure. As the tire rolls this creates a lot of heat in the sidewalls. Heat and UV are enemies of rubber compounds. An archive search might yield information that I have shared in the past.
Here is another way to look at it. The tires on your car typically have a rated inflation pressure of 35 psi and one typically operates one's car well below the gross axle weight rating that the tires have to be sized for. How long do you think they would last if they were routinely inflated to only 17 psi?
The saving grace here is that our aircraft tires don't get "driven" very far. How many miles do you travel on the ground to make 300 - 500 landings? On the other hand, nylon bias ply tires are sure going to "flat spot" at low inflation pressures while the plane is in the hangar, which makes it difficult to pull the plane out of the hangar and will certainly give one a "hoppy" taxi out to the runway. Perhaps in this case one actually wants a lengthy taxi so the tires are actually round before the take-off roll!
Larry
Old 10-07-2009, 12:22 PM
db1yg's Avatar
db1yg db1yg is offline
I have tried a number of combinations and have also settled on 40 in the mains and 40-45 in the nose. I use the Goodyear FC III tires and airstop tubes in the mains. I also wish there was a better quality option for the nose gear tire--haven't found one yet!!
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 10-07-2009, 12:30 PM
flyboy1963's Avatar
Default Tire pressure - RV-9a
I try to keep the mains at 35-40 and the nose at no less than 30, cold.
no shimmy problem, just want to have proper contact, and not end up on my nose if the worst happens.!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 10-08-2009, 08:49 AM
Steve Steve is offline
I put 35 psi in my 9A front tire.
Five Sierra Fox
RV-9A
Utah
