Fuel Flow Transducer Problem
...has surfaced over time. This is on an IO-360 with GRT/EIS400 sytem. First it would occasionally read zero on startup but then kick in upon taxi. Now as an extreme case it will read from zero to 30 gph, back and forth. Has anyone experienced this kind of wild fluctuation and what was the resolution, Transducer, wiring, EIS? I first suspected the T-ducer but can't imagine what would cause it to read 30+GPH...
No, have not called GRT yet, but emailed them when first read zero, no response.
Ideas?
Jerry
