10-03-2009, 11:22 AM
seat belt HW
My seat belts from vans did not come with hardware for attaching to the structure. I'm guess AN-3 bolts?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
10-03-2009, 05:00 PM
VAF Moderator
Check the plans
But I believe that Vans calls for AN-4 hardware
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
10-04-2009, 02:30 PM
I believe all hte plans show is the hardware for attaching the brackets and the shoulder-harness cable to the structure. Since seat belts don't come standard with the kit, I don't think the plans actually show what to use to bolt the seat belts to the anchors. The seat belts themsleves don't come with any hardware or instructions for this.
Phil
RV9A (SB)
Ottawa, Canada
10-04-2009, 03:42 PM
VAF Moderator / Line Boy
Plans or not, Gary is right - AN4 - at least!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
10-06-2009, 06:52 AM
Phil,
AN4-6 for shoulder and lap. Also need spacers to go in belt holes. 3/8 dia with 1/4 hole, 3/16 wide.
Steve
10-06-2009, 07:08 AM
strange that Vans' doesn't provide these spacers! Any idea where spacers of those specs can be obtained??
Phil
RV9A (SB)
Ottawa, Canada
10-06-2009, 07:16 AM
hardware is with the fuselage kit, spacers are fabricated. see detail e on sheet 29.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
10-06-2009, 06:10 PM
hmmm... looking at DWG 29, detail e shows the assembly, and the drawing shows the spacer F-7116 being made from AT6-058x5/16, and the spacer is marked as having 5/16 diameter. But Steve is right, 3/8 is a much better fit. The holes in the seat belt are slightly larger than 3/8. Is this an error in the plans?
Also, the drawing says "4 req'd per aircraft". Shouldn't the same spacers be used for the holes in the shoulder harnesses, which are the same size (just over 3/8") ??
Phil
RV9A (SB)
Ottawa, Canada
10-06-2009, 06:38 PM
You should have a small length of 3/8 OD x 1/4 ID al tubing to make six of the spacers.
Steve
10-06-2009, 07:13 PM
Yes I do, but see my previous post above. The plans call for 5/16 OD which seems too small. I also have some of this tubing, but I'm wondering if the plans are mistaken here. I've emailed Vans.
Phil
RV9A (SB)
Ottawa, Canada
