Old 10-02-2009, 08:07 PM
Jamie Aust's Avatar
Jamie Aust Jamie Aust is offline
Default Starter MZ-4222R, Help
I have the above starter. It is about 13" long for my 0-360 engine.
Does anyone know if it will fit ok for my 7A cowl. As I have not put the engine onto the mount as yet, I cant do a test fit of it.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
Old 10-02-2009, 10:45 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Yes it will fit
Jamie,
That's what I'm running. It turns a little slower than the newer starters.
There's room for my thumb between the nose of the starter and the cowling.
Sounds like a Mooney cranking up, but's that's OK
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 10-03-2009, 12:07 AM
Jamie Aust's Avatar
Thanks mark,
How much room do you have behind it ? what does it come close to, being 13" long.
This one is from a mooney its was a io-360 b1e, now its a 0-360 A1A, do you see any probs with this setup ?
I will be running a catto 3 blade, and it will be on an 7A nose wheel mount.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
VH-XJL
Old 10-03-2009, 05:48 AM
pierre smith's Avatar
Default Hi Jamie
FWIW, my buddy runs one in his -4 for CG reasons since he also has a Catto two-blade.
I have a Skytech starter on my -6A and a three-blade Catto with no CG issues.
Use it and do a weight and balance and it should dictate whether or not you need the weight up there.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-03-2009, 08:16 PM
Mark Burns's Avatar
Thanks mark,
Jamie,
I found a photo. It's not a real good photo. You can't really tell how much room there is between the starter and the oil sump. But it's enough. And there is plenty of room between the starter and the carb heat muff also.
I've got the 40lb Sensenich prop on my 7A and the weight and balance was good with this starter. If I remember correctly this starter weighs 14lbs! My engine was off of a Mooney also. An M20G. It's an O-360-A1D.
Mark Burns
Ruston, Louisiana
FFI FL-24
A&P
Old 10-04-2009, 02:57 PM
Jamie Aust's Avatar
Smile
Thank you both for the feed back. I hope the weight will help up front as the Catto is about 10 lbs lighter than the sensenich.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
VH-XJL
