View Poll Results: If you have paint blisters over the rivets, are they;
Riveted skin only, NO proseal or fuel exposure 2 6.06%
Riveted skin, proseal but NO fuel exposure 3 9.09%
Riveted skin, proseal AND fuel exposure 28 84.85%
Other location, please explain in a post, photo if you can. 0 0%
Multiple Choice Poll. Voters: 33. You may not vote on this poll
Old 09-30-2009, 09:31 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Paint Blister Poll
Trying to see if we can help to identify the cause of the paint blisters.
PLEASE REMEMBER THE TANK REAR BAFFLE IS PART OF THE AREA EXPOSED TO FUEL.
You can vote for more than one.
Thanks for adding info to the pool.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-30-2009, 10:01 AM
Ironflight's Avatar
VAF Moderator / Line Boy
You might think of adding a bullet "I have no blisters".....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-30-2009, 10:03 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Not sure why we have choices for anything other than tanks.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 09-30-2009, 10:05 AM
Mike S's Avatar
Senior Curmudgeon
Just to be totally sure of the cause.
If a bunch of folks check the "porseal, no fuel" choice, then we know that it is the proseal itself (at least partially) causing the issue.
All just data points.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-30-2009, 10:06 AM
Mike S's Avatar
Senior Curmudgeon
Dont think it is necessary, the poll is titled "If you have ----"
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-30-2009, 12:07 PM
rleffler's Avatar
rleffler rleffler is offline
I agree with Paul.
For example, what if 80% of the a/c with the variations you are polling don't have blisters? That would tell you that the root cause may be something else?
While the sampling may never be able to reach the entire RV fleet, it would be nice to attempt to understand what percentage of the fleet is impacted by blistering.
The population on VAF is probably a large enough sampling to produce significantly interesting data.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-30-2009, 12:25 PM
hecilopter's Avatar
hecilopter hecilopter is offline
Default Since I really want this solved
I thought I would post what I think is other relevant data:
1) I have blisters on the top of my tanks only, and entire rivet lines not just a few random rivets.
2) My tanks were slow built and leak tested with air, no leaks for 3 days. All shop heads of the rivets and rib/skin seams are sealed with proseal (ie, I probably OVER did it).
3) I flew my plane over a year or 150 hours before paint.
4) The tanks were completed in a HOT hangar in Texas about 3 years before painting.
5) I used the pro seal from Van's
6) I used the special tank dimple dies available from Cleaveland that dimples the holes a little deeper to account for the proseal
7) My painter sanded and filled all rivets on the top of the plane to give it a composite look (see pic below)
8) paint on the tanks is Jet-Glo Matterhorn white, clear coat on top of that. Unsure about primer.
9) It took about 8 months (and a HOT summer) post painting for the first blisters to show up
10) I have never had any leaking from the fuel tanks top or bottom, nor any liquid at all after popping at least 20 of the blisters.
11) I am uncertain about what solvent was used to clean the surface or the type of paint thinner used in the paint
Rusty "Rooster" Williams
N357RV RV-7A Tip Up (flying and Painted!) - 1560+ hrs.
Superior XP-360, carbureted, Hartzell 74" Blended Airfoil Prop
Grand Prairie, TX
KGPM
Old 09-30-2009, 12:54 PM
Mike S's Avatar
Senior Curmudgeon
Originally Posted by rleffler View Post
I agree with Paul.
Bob, not to be argumentative, but I dont see the value of collecting that info.
We are trying to determine the common factors in planes with the blisters.
The planes without blisters would be just "noise" in this data set.
Make me understand the value of collecting that data, and I will be happy to add the choice.
I suspect it might be a better thing to collect data on if you have a blister or not, all by itself in a new poll, than adding this info into the above poll.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-30-2009, 01:25 PM
rleffler's Avatar
I don't have blisters (yet) since I'm not flying nor is my a/c painted, so my interest in this may not be as engaged as others. However, nobody has been able to demostrate to Van's the percentage of the fleet that is impacted. The larger the percentage, the more likely you'll be able to better engage Van's in getting some engineering assistance.
Van's sometimes pleads ignorance when individuals call with issues stating it's the first time they've heard about the problem. However, if you can substantiate that x% of the fleet is impacted, that will get attention. It may very well turn out to be more process orientated as oppose to anything Van's did, but I think it they understood how large a population is impacted you would get some assistance from them in identification of the root cause.
Also, take this example:
100 RVs sampled
2% proseal w/ no fuel and blisters
98% proseal w/ no blisters
What conclusion would you assume? It would only lead you to question what are the 2% doing that the 98% aren't. Are they following a different process? Are they using the same proseal? Are they using the same solvents for cleaning? If the majority aren't expeiencing blisters, then what is causing the problem?
You could do this with each of your poll options. At this point there is no definitive root cause that has enough statistical data to prove it's the only cause. We have a lot of very intelligent hunches and/or suspecions. If you only look at the 2%, you may be led to make a bad assumption.
I don't mean to be argumenative either, but I think you are just scrating the tip of the iceberg with the data points you are collecting. With that said, I'll crawl back into my hole and be quiet.
Bob Leffler
Old 09-30-2009, 01:53 PM
Mike S's Avatar
Senior Curmudgeon
Default You are right, but it is a different issue.
I don't mean to be argumentative either, but I think you are just scratching the tip of the iceberg with the data points you are collecting. With that said, I'll crawl back into my hole and be quiet.
NO, dont do that.
Your input is just as valid as anybody, far as I am concerned.
I totally agree with you that we have a better chance of getting help from MotherShip if there is a high % of painted planes with blisters.
This is a two edged sword however, and may very well be for slicing our own throats, because if only a statistically small % of the total fleet has the problem, then Vans position ----not going to deal with it----is supported.
I still think that in an effort to determine the cause of the blisters, that %age of the total fleet with blisters is not a relevant data point, and does not need to be collected.
Mike Starkey
VAF 909
Rv-10, N210LM.
